Kaimana Weight
Kaimana Weight
The weight engraved behind the left pedal on a Kaimana...is that the fully rigged weight or the hull weight...
Submitted by nb1376 on
I think it's hull weight only. Check by stepping on a bathroom scale with boat fully rigged and then with hull only. That should give you an answer.
Later
#1 Mon, 12/04/2006 - 5:45am
Just to give you an example of my Kaimana component weights (I measured them on a digital scale). My Kaimana the boat alone weighs 23 lbs, the Iakos are 1 pound each and the Ama itself is 4 lbs. Total weight rigged is just under 30 lbs.
#2 Mon, 12/04/2006 - 10:17am
whats the number behind the foot pedal pittbrah???
#3 Mon, 12/04/2006 - 1:23pm
Hey NB,
Sory can't check that right now. Boat is on the roofrack of my car in a cover right now keeping the SNOW off! I'll let you know when I can get that information ;-)
Cheers....
#4 Tue, 12/05/2006 - 5:34am
Page loaded in 0.123 seconds.
