Storage of OC-1
Storage of OC-1
I was wondering that best way to keep my fusion in the garage.
Should I hang it form the celing or the wall?
what do you guys do?
Submitted by poiboy20 on
PoiBoy,
Brah when I got my canoe, I measured the inside of the garage to ensure that I had room. Then I bought from Go bananas in kapahulu they have surf racks with padding, I found studs screwed it into the wall and there you go you have canoe rack. Make sure you have an even length I did a chalk line to make it even
Nalu
#1 Fri, 03/31/2006 - 12:33pm
I just picked up a pair of 'ladder' hangers from Home Depot for like $5-6, it even comes with foam pads. I just mounted it to the side of my garage. I live in NY, so the last thing I want is to store my Oc-1 outdoors during the winters.
#2 Fri, 05/19/2006 - 4:13am
Whatever you do, make sure that the contact points of your rack or straps on your canoe is as large as possible. If its racks, most people use pipes which are the worst cause there is a small surface area bearing all the weight of your canoe which can over time cause a pressure dent. Use something squarish. That's just from my experiences.
#3 Fri, 05/19/2006 - 12:57pm
Page loaded in 0.124 seconds.
