Switching sides/strokesper min.
How many strokes does one usually take before switching sides? I have been paddling my OC-1 since May and have taken to a 1 minute or 60 stroke pattern on each side. Today I decided to switch to 30 strokes per side on my last lap of my workout and completed one of my 2 mile loops 25 sec. faster than usual. Any suggestions?
Zumapop
Submitted by zumapop on
If less equals more, then do less...
...on each side that is.
Cut it in half again to 15 strokes per side, and you just might be ANOTHER 25 seconds faster.
#1 Wed, 09/12/2007 - 4:04pm
Seems like most common is in the 15-25 range.
#2 Wed, 09/12/2007 - 5:52pm
I find that doing a whole run on one side works for me. I then do the next whole run on the other side. I mean it would be dumb to just work on one side and never use the other.
(seriously, for me 15-30)
#3 Wed, 09/12/2007 - 8:10pm
Or, you could kayak and switch on every stroke.
Seriously, in my 6 man crew at Hui Lanakila I sit in seat 2 a lot and my girls would throw me out of the canoe if I went over 20 strokes per side too often. Usually, at long distance race pace, it will be between 15-18 max. Sprints a few less per side.
If you can go an entire minute on one side you should think about doing the Olympic canoes (C1, C2, etc.) They never switch sides. Switching sides well is an important part of keeping the boat running and the better you are at getting a good bite on the first stroke on the other side the better the boat will glide.
Mikala
#4 Thu, 09/13/2007 - 6:56am
I have been wondering about this myself. I have just started doing structured workouts, as opposed to just paddling for an hour or two.
Earlier this week, after a warm up I did four 2 min intervals at the fastest pace I could hold with 2 min recovery, then cruised for 10 mins or so to prepare for a short test.
I paddled from one predetermined point to another - a distance I know to be 3 miles. I was trying to keep a 60 stroke per min pace, switching approx every 15 strokes.
When it was all said and done I covered the distance in a little over 26 minutes and averaged 6.8 mph on totally flat water, no wind, no current.
Questions are: is 60 stokes per min typical of "race pace"?
Is 3 miles a good indication of what I might be able to do over a longer distance?
I am using an wide wood paddle (9.5 inches or more)...would a narrower paddle be faster for OC1?
Is the pace I paddled relatively competitive for short or medium distance races?
Thanks in advance for your input and advice!
Raphael
#5 Thu, 09/13/2007 - 9:30am
jh
I've found 15 is the best number of strokes on each side for me. When I started I did way more, thinking that switching wasted time and made me slower. Over time though, I came to realize that the time is made up because you don't push the specific muscles associated with paddling on one particular side past their fatigue threshold. Though the stroke is the same on each side, your using different muscles, when you switch your sort of resting the muscles from the other side. If you switch too often, say every 10, I think then you'd be spending too much time switching sides. This is just my opinion though.
#6 Thu, 09/13/2007 - 10:18am
In swimming it is a matter of stroke length and stroke rate.
The Australian Thorpe has one of the longest stroke length, and interestingly also one of the highest stroke rates. Together = world champion.
They train these things with a little beeper that they put under the swim cap.
For example: 200 meter intervals, allowed time 2:05 - 2:10. First pass the beeper goes every 0.7 secs. Second pass every .9 secs. Third pass every 1.1 and fourth pass 1.3; then down again.
These are just examples. With a stroke every 1.3 secs you have 45 strokes for the same distance, with 1 sec you have 60/min.
The crucial thing: you have to keep the same speed.
This way they train efficiency and stroke length.
The actual cadence depends on the conditions. Flat water is different from open ocean; usually triathletes have higher stroke rates than pool swimmers.
Paddle size: there is an interesting article about Danny Ching; they reduced the blade size by 0.5 inch every hour in a long distance race. With every blade size their speed dropped after about an hour and they were able to bring it up again with the smaller blade. 0.5 knots/hour difference.
#7 Thu, 09/13/2007 - 10:40am
I agree with jh, your large muscle groups will fatigue and your stroke rate and power application will suffer if you stay long on 1 one side, whoever is doing that must be doing the "all day long" stroke or bottom fishing. Nothing wrong with that, but your not going to win any race.
Interesting info about paddle size eckhart. I wonder what the conclusion was to that? Use a smaller blade throughout? Or change paddles as you go?
#8 Thu, 09/13/2007 - 10:55am
nemO, the conclusion was that they need to do more testing, as they did not record data on how the blade changes effected stroke rate.
The Danny Ching article is here
http://rambos-locker.blogspot.com/2007/07/discussion-about-paddle-types…
#9 Thu, 09/13/2007 - 11:18am
I'm still a "noob" to OC paddling after only starting at the beginning of the year but I've been getting out on an OC1 a fair amount the past couple of months and I'm nutz about it.
I had a great paddle this past Monday morning. The lake was like glass and I took off with a Garmin Forerunner to see how my stroke was progressing side to side and efficiency-wise. After a short easy warmup I went into a 12/side rhythm concentrating to keep the power up front after a good entry. After a couple laps I was keeping the speed pretty consistent at what I think was about 60spm. On the last lap I went into a 40/side rhythm with a shorter/faster stroke. I was suprised to see my speed increase, not a ton but a little, and stay even more consistent.
I'm not sure yet if it was the 40/side and/or the shorter/faster stroke but I keep thinking of what I've read and seen of the Tahitian stroke style and rates and have to wonder.
#10 Thu, 09/13/2007 - 1:02pm
Hi nem0,
as usual it depends.
Energy expense is lower with a larger paddle and a slow stroke rate; due to a lower heart rate.
However, you tend to get stuck or maxed out with that rate and you cannot react to changing circumstances as well; lets say trying to get on a bump; trying to burst your speed to catch up to someone; the sprint to the finish ...
I reduced paddle size - also length - and went faster with a higher rate.
I think it is pretty much the same as in biking: you can't go uphill in your largest gear etc.. Not different in paddling.
#11 Thu, 09/13/2007 - 2:00pm
Well, Today, after two weeks or so at 30 strokes/ side I dropped down to 20/ side per goto's comment and shaved off another 20 sec. I know this can't go on, but I'm going for 15 after a another couple of weeks. One thing I am finding is it does increase the # of strokes/ min by reducing 3/side, despite changing over twice a minute. Thanks for the input.
Zumapop
#12 Tue, 09/25/2007 - 5:06pm
Zumapop, the 20 sec saving is probably a fitness adaption over a couple of weeks as a result of the extra stress of paddling 30 strokes/side. Dropping down to 20 strokes/side and being faster, just proves that what you did works for you as a training drill.
Do it with more intensity next time and see if you can improve even further. Good work.
#13 Tue, 09/25/2007 - 7:09pm
I know it's all personal preference but what paddle size do OC1 paddles tend to use? I currently use my OC6 paddle which is a 50"x9.25".
#14 Thu, 09/27/2007 - 7:39am
For paddle length, someone once told me, while standing up straight and holding the paddle up straight on the ground in front of your chest, the paddle handle should come up to you nipple.
If any women need help with paddle measurements, just send me a private message.... and my wife will be happy to help you out. sigh
#15 Thu, 09/27/2007 - 8:04am
What's the tendancy toward blade width in OC1? What is "narrow", what is "wide"?
Thanks in advance!
#16 Fri, 09/28/2007 - 8:04am
swell paddler. Since the oc1 sits a little lower to the waters surface (especially my pegasus) I went a little bit shorter on my shaft. Approx. an inch. doesn't seem like much, but sure feels like much. It really makes a difference when you want a higher stroke rate. (like catching the bumps)
I also like the shaft a little stiffer since the pulling weight (6man canoe -vs- 20lbs OC1) is different. With the added stiffness (like carbon fiber......don't forget the lite weight of composite materials) seems to be more responsive out in the ocean. Also the stiffer sharft doesn't put as much stress on your shoulders or body on the OC1 than it would on a 6man.
Verdict for OC1 paddle (personal verdict)
  1. an inch or inch half shorter than a 6man paddle
  2. a tad bit stiffer
  3. lite weight (carbon) My personal OC1 pick is the Makana Ali'i Paddles wood or hyrid. Has a great feel and is super lite. Wanna get one, good luck with that!
#17 Fri, 09/28/2007 - 10:09am
Thanks Tango.
What's your blade width?
#18 Fri, 09/28/2007 - 10:14am
I've been playing around a lot recently with paddle width. About 3 years ago i went from a Makana Ali'i to a Mudbrook, and in the process dropped almost an inch from the width (not entirely positive, but i think from a little under 9.5" to a little over 8.5'). I was really happy with the decrease, and for about the last three years i've been a big proponent of the smaller paddle. However, i recently bought a 10.25" paddle in Tahiti that i've been using in the rudderless.
I've found.. in the flat, with nearly an inch and a half difference there isn't a whole lot of difference in my speed (w/ Garmin) in the rudderless. I haven't really looked at my speed over any kind of distance in the flat, this is only during sprints. But, in the ocean the bigger blade in the rudderless seems to be pretty key. I dont know how translatable this all is to an OC-1. If i try and use the bigger blade (double bend as well) in my Kainalu, i feel like i am paddling with a log. My instinct has always been to paddle with a smaller blade in bigger conditions and a bigger blade in flatter conditions, but this has been reversed in the rudderless and now i'm stuck and don't know what to do. All i know is that if i had to do a long distance race tomorrow in the OC-1, i'd take my smallest mudbrook, and if i had to do anything in the rudderless (unless it was really long and flat), i'd use my 10.25" tahitian blade.
I guess the moral of all of that is... it really depends on what the ocean and canoe is like... i guess body type too, i'm pretty scrawny, which is another reason i've always assumed smaller would be better for me.
As far as switching sides... with the smallest width paddle i have i rarely go above 15 (though it varies A LOT). And with the biggest mudbrook i have (9.5") i dont think i go much above ten strokes per side.
alright.. that's all
#19 Sat, 09/29/2007 - 7:04am
Another dimension to think about is when paddling a rudderless canoe with a side wind. The World Sprints at Hilo was very difficult since if you couldn't manage to paddle steer perfectly, then the side wind pushed the canoe badly. This required almost an entire 500m paddling on one side. What a burn out.
Another thing is when catching waves. I end up paddling mostly on the right, then switching to the left in between waves.
So practice paddling a lot on the same side isn't bad, but in normal conditions doing the 15-20 per side works.
As for paddle width, I still use my Lanikai 9-3/4. Maybe I just like the name and place, but it works for me.
#20 Sat, 09/29/2007 - 5:21pm
The number of strokes per change affects your power output / hull speed more than you think. Most long change cycles 15+ strokes are often a result of crappy change technique.
On paddling ergs (which require no real "water technique"), paddlers who have excellent change technique and fitness can maintain their top speed on intervals and simulated time trials using as few as 3-8 strokes per side, whereas paddlers with poor change technique can take anywhere from 10-30 strokes to rebuild speed.
In the skilled paddlers, power output drops off fast after 8-12 strokes then settles in from 20-40 strokes, but at a much lower speed than their optimal speed they can maintain at 8-12 strokes a side.
The less skilled paddlers were unable to maintain their hull speed in the 8-12 stroke range as they were still recovering speed from the change itself and ended up needing more strokes a side (20+) for their optimal speed.
The challenge in learning to do efficient changes is realizing that there are three distinct strokes in each change cycle;
    the last stroke of the series,
    the first stroke of the series and
    the strokes between the first and the last stroke.
The biggest differences occur on the first and last strokes. There are changes in technique evident in;
    core stability,
    stroke length,
    stroke rate,
    force per stroke and
    what muscles sequencing and force production.
V1 paddlers have to learn to change on any combination of strokes at any time to suit the water and wind conditions. There have been rudderless races (i.e. Super Aito in 2006) where almost the entire event was on one side for over 3 hours, to sprint races where ratios can be anywhere from 1:3 to even 8:8 or all on one side.
Have fun!
#21 Wed, 10/03/2007 - 7:23am
Hey Allen
if I was in a rudderless 2 or 3 stokes a side. depending on how much rocker there oc has, and add in current or wind and you could be on one side for a while .but if there was no current or wind 2 or 3 stokes to keep it straight.
and add a rudder and go to 15 and you are dragging a rudder for 12 strokes which slows the canoe much like if you were in a 6 man and the skipper was poking and not pulling.so I would say 3 a side.
paddle size on a day to day 9 1/2 and in the height of summer or in the 6 man canoe I could use a 10 1/2 I tried a 8 1/2 and It teaches me technique all over again reach dig to get water but race day it stays home. I like a quick blade 52 inch.
#22 Tue, 11/20/2007 - 9:30pm
Is this a joke?
#23 Wed, 11/21/2007 - 7:16am
wich part paddle or strokes?
#24 Wed, 11/21/2007 - 5:14pm
or a J stroke and you could stay on a side all day
#25 Wed, 11/21/2007 - 5:16pm
Page loaded in 0.426 seconds.
