I guess this helps put the "leg drive" question to rest!
The question is, would you be able to keep that up continuously for a long distance race? Imagine the chaffing/rash you'd get from that constant back and forth motion in the seat. Even with Glide or wearing nylon/spandex shorts underneath, you'd still get the heat from the friction produced.
There doesn't have to be that much movement of your behind (especially) in a stationary seat to use legdrive. As mentioned before, you just need to put pressure on the leg that you need the support on while relaxing the other and then switch as you change over. If you watched some of the K1 races in the Olympics, you would have seen legdrive being used as they stroked their way down the course. You would have noticed their knees alternating going up and down.
Same goes for SUP paddling, you put pressure on the side (bracing) while still maintaining the same even foot placement. Some bend at the knee while some don't, but they all benefit from legdrive/bracing to support their core while in the stroke. Plus less movement of their foot placement is one thing less they have to worry about (re-establishing balance) and less waste of energy.
#2 Sat, 08/23/2008 - 12:49pm
How is leg drive a question? Simple physics and physiology says you can't go fast without it.
#3 Sat, 08/23/2008 - 1:20pm
leg drive can be questioned in th' same manner that ye nereneed t' blink while ye be sleepin'.
#4 Sat, 08/23/2008 - 1:38pm
The video does not show real 'leg drive', imo.
The V1 have no foot board or anything you can easily push against, it's one hollow tube.
Some guys were wearing rubber shoes to get some grip, some put a rubber mat into the boat.
I guess by 'jumping' forward as in the video you get more pressure on the seat and on the feet and with that more friction - and overall a better transfer of the force for the forward movement.
The seats are just as slippery as the floor.
It is not easy to transfer your energy if you are not used to paddle these boats; the video shows how it can be done very effectively.
It seems that both knees are bent almost simultaneously.
#5 Sat, 08/23/2008 - 5:10pm
Shawn
Danny Ching took part in a long distance race/test.
About every hour their average speed dropped; they changed the paddles and continued with a blade 1/4 (?1/2) inch narrower - hull speed went up by 1/2 knot/h after every change and they were able to hold that new speed for about another hour.
AFAIK, they started with 9 1/2, then 9 1/4, 9 and 8 3/4 or 1/2. The report is somewhere published on the internet.
Just give him a call and see what he thinks about blade size these days.
Physically a larger paddle is more effective - more mass of water /volume per stroke - and in sprint this holds true in real life.
Over long distance a large blade will fatigue your paddle specific muscles earlier, even though your overall energy consumption may be less.
#6 Sat, 08/23/2008 - 5:21pm
The article Eckhart is referring to is here in the Locker
http://rambos-locker.blogspot.com/2007/07/discussion-about-paddle-types…
#7 Sat, 08/23/2008 - 5:58pm
All - most :) - good things can be found in Rambo's locker - thank you for the update.
#8 Sat, 08/23/2008 - 6:06pm
You are welcome my friend, it's halfway down the page.
Cheers The Locker Man
#9 Sat, 08/23/2008 - 6:13pm
shawn, yer aim ortin' ta be t' nerecavitate, e'en when ye be fresh. pull as hard as ye can without causin' cavitation. also, swabbies be havin' th' common belief that they be pullin' th' paddle through th' water. nay so, they be stickin' th' paddle in th' water 'ere 't ortin' ta remain still, an' th' canoe ortin' ta be pulled past th' stationary blade. so th' reason a large blade feels like 't requires more effort be that ye be havin' less energy bein' spilled off an' around th' edges o' a larger blade while 't sticks in th' water.
#15 Sun, 08/24/2008 - 6:55am
Shawn
Look up the 'Excalibur' - unfortunately it is not a OC paddle but a dragon boat paddle - it is set up to record the deflection of the blade during your pull. You can then interpret your results on screen.
If there is an electronic genius out there, I'd like to know how difficult this would be to rebuild for an OC paddle.
It is done with a strain gage, a Wheatstone bridge, an AD converter plus an amplifier as well as a blue tooth transmitter.
The hardware/software for display can be done with National Instruments.
Rambo, are you fit in that area ?
#17 Sun, 08/24/2008 - 7:49pm
I don't have blue teeth, i would never cross a Wheatstone Bridge and last time i looked i was DC so no chance of converting. Maybe Poopoo could help with the strain gage.
Sorry Eckkie.
#18 Sun, 08/24/2008 - 8:09pm
Rambo, I see that your DC-ness poses a real problem here ...
There is a white paper from an Australian University that describes an entire setup for a kayak that can measure trim, roll, acceleration, GP etc and also pressure on the blades.
title ... system for kayak ... ???
For someone that knows a little about electronics it cannot be too difficult; I have to pass on this one, too.
It would be neat if you could compare the pressure curves of the individual paddler's pull of your OC 6 team on screen and maybe optimize performance.
I don't dare asking poopoo - he seems quite strained already.
#19 Sun, 08/24/2008 - 8:20pm
I don’t dare asking poopoo - he seems quite strained already.
does he have (hemor)RHOID RAGE?
#21 Sun, 08/24/2008 - 8:28pm
Did you see Real Madrid beat Valencia in the 'Supercopa' - online tv streaming ?
They were 1 man down at 0-1, scored for 1-1, had another expulsion and scored three goals to win 4-2.
I've never seen 9 against 11 score three goals to win in a cup final !
Quite exceptional.
Hala Madrid.
A little off topic.
#22 Sun, 08/24/2008 - 8:30pm
No, his strain looks healthy - see avatar.
The 'butt aid' makes you wonder, though. Maybe you are right.
#23 Sun, 08/24/2008 - 8:33pm
I tried that software Shawn, and my perfect Ghost overlay turned out to be Casper .... so much for my technique.
Rambooo...ooooh
#24 Sun, 08/24/2008 - 8:34pm
I think the Excalibur as well as this software deserve to be reviewed on Rambo's Locker.
#25 Sun, 08/24/2008 - 8:37pm
Few comments,
Dannys blade that he used in the finals at Worlds was probably one of the smallest volume blades I've ever used. But using this blade he crushed the first half of the race and then got passed by like 6 Tahitians (surprise I know...)
Also, about a year or so ago I stayed at a guys house who is a buddy of a guy I paddle with and also a technical genius. He was working on exactly what you are talking about above with the electronics for measuring paddle flex and other information. Unfortunately I haven't seen him since or heard anything about the project so I'm not sure what became of it and don't have any way to get ahold of him.
Finally, I paddled in a dragon boat race in long beach a few weeks ago. World Qualification or something I think. I really appreciate changing sides every 20 strokes now.
#26 Sun, 08/24/2008 - 8:54pm
http://209.85.141.104/search?q=cache:phvtw57qGboJ:fseh.cqu.edu.au/FCWVi…
I hope the link works: it is about the 'kayak training aids' - google; Australian ministry of sports
#28 Sun, 08/24/2008 - 8:58pm
And here's the Excalibur video
http://www.abc.net.au/tv/newinventors/txt/s2203885.htm
#30 Sun, 08/24/2008 - 9:03pm
It seems that there's probably something in the shaft that measures flex? Can't be that hard to adapt for paddling. But the question is why? If you know how hard you're pulling then will that allow you to pull harder?
#31 Sun, 08/24/2008 - 9:57pm
poops
Actually the answer is yes. On bikes we use power meters which measure the actual wattage you produce. They use a strain gauge that measures deflection either at the crank or the rear hub.
So If you're putting out 300 watts, you fight to maintain that, or fight to put out 305, etc. Totally independent of terrain, wind, speed, etc. Just how much power you are actually producing. It really is a good training aid, but costs $$$.
#33 Mon, 08/25/2008 - 6:44am
Ahh makes sense. Interesting. I guess its like GPS showing speed. You paddle harder to maintain higher speed than you normally do. Makes sense.
Off topic jibofo, did you see the Laird Hamilton special about how he trains? They have a group of like 8 guys who mountain bike and they weigh their bikes down to keep them even in trail runs. So laird has like 60 lbs on his bike and ends up burning his brakes on every run. Crazy
#34 Mon, 08/25/2008 - 8:22am
poops
Even better than GPS. If you say 7mph, is that upwind, downwind, smooth choppy, current, etc. If you say 300 watts it removes all the variables. But for the bucks, GPS is a great aid.
Haven't seen the Laird Hamilton bit. Sounds sort of like the guys running along the bottom of Waimea Bay during the summer carrying heavy rocks to keep them down. Way too serious.
#35 Mon, 08/25/2008 - 8:52am
poopoopaddler
the strain gauge is mounted on the backside of the blade and measures the deflection. For details see the link ' kayak training aid' posted above.
On screen you can see pressure versus time curve; it tells you when the paddler produces max pressure in his stroke; also overall performance etc.
You can see exactly how effectively paddler in 1,2,3 etc seat works under water. You could synchronize the entire crew better.
#36 Mon, 08/25/2008 - 9:52am
The Excalibur seems to be an okay tool. But, it might have limitations. I’ve installed a few (hundreds) strain gauges on military hardware over the years and have a little insight to they’re operation.
The gauge’s internal impedance changes when the gauge material is deformed, or bent. If you know the physical properties of the material the gauge is mounted to, i.e. type of metal, thickness of the metal and axis of expected material deflection, it’s possible to compute the strain on the material by collecting calibration data of known pressures applied to the material and comparing that data to the data collected during the test.
The problem I see with the application of a strain gauge to a paddle is the ever changing position of the paddler’s lower hand on the shaft and the stroke speed. Sure, you could “peg the needle”, so to speak, by applying a quick, short jerk but as you move your hand up and down the shaft, the deflection of the shaft is going to change and so are the gauge readings because the paddle will bend over a longer area of the shaft as you move your hand up causing the area the gauge is mounted on, to bend less.
I think the application of this paddle would only give you a vague comparison of each paddler’s stroke, not quantifiable stroke by stroke pressure levels and times.
Joe
Lihue, Kauai
www.vrataric.com
#38 Mon, 08/25/2008 - 10:59am
Not exactly sure how small the blade Danny raced with was but it was probably about 8" 3/4 or maybe 9" at the most.
#39 Mon, 08/25/2008 - 11:17am
OC 1 Driver
that is very interesting. Do you see a way to work around this ?
The stroke speed could be accounted for by measuring the hull speed and countinng the strokes/min..
On the other hand, you may be able to tell a paddler his optimal stroke speed and hand position ?
#40 Mon, 08/25/2008 - 12:49pm
I think if there was an accelorometer incorporated into the shaft you could get better data on the stroke speed and consistancy.
Joe
Lihue, Kauai
www.vrataric.com
#41 Mon, 08/25/2008 - 9:28pm
I'm with Poo; why is leg drive even a question? Try a fixed seat dory than go row a slider, then go paddle an OC you'll naturally want those legs involved. If you had a sliding-seat on an OC1, imagine the power you'd get...Anyway; good vid it illustrated leg push well, among other good techniques. As for going long distance just trim everything back a bit for efficiency; you don't have to move butt back & forth to incorporate solid leg-drive.
As for Dragonboating Shawn; just go hook up with a club and do some practices. I thought OC looked silly until I tried it. Sports are always different when experienced than observing. I tried dragonboats this Summer and had a bunch of fun; good people... 1000 Meter sprints on one side not be for the timid....
Cheers
#42 Tue, 08/26/2008 - 4:02am
"As far as I can see, there are a lot of very successful paddlers who do not use any visiable leg drive"
Try to holding your legs up when you paddle. Try doing anythin in a seated position w/o your legs......like cutting a steak.
#45 Tue, 08/26/2008 - 10:23am
Not sure what you mean by slow...Dragonboats move faster than you think...just take your bicycle to the start line of a race and follow them you'll see.
Agree with Aqua; EVERYBODY uses leg drive even if it looks like or they say they don't...even rookies who're just learning to paddle.
#46 Tue, 08/26/2008 - 1:04pm
As far as I can see, there are a lot of very successful paddlers who do not use any visiable leg drive and use their weight and the friction of their butt in the seat to stabilize. The leg position and the lack of any leg flexing/movment seems to point to that, but I might be mistaken.
Just because it isn't visible doesn't mean it isn't being used. If legdrive wasn't needed, you wouldn't really see the need for any footwells to brace against in kayaks, surfskis, and other crafts. Without a stable footing, you'd literally fallout while paddling unless you were strapped in your seat.
In an OC6 (or any type of canoe), if you were to keep your knees closed and your feet together centered in front of you and try to paddle, your body/core will naturally swing them towards that side of the gunwhales for bracing after a few strokes, .
#47 Tue, 08/26/2008 - 2:35pm
One time our stroker had bike grease all over his feet and tracked it over the whole canoe as he climbed to the front from the back. It was the worst practice ever, all our feets were slipping and slidin. It was terrible. Yes leg and feet are very very important.
Anyone who says leg drive isn't important is probably saying that because he's having trouble doing it and trying to justify not doing and probably is pretty slow. Think of paddling like a tug of war. same same. Without your legs and feet its impossible to win.
#48 Tue, 08/26/2008 - 3:21pm
Dragon boats are very quick with the right crew the world record for the 500m is 1:48 and change try doing that in a OC1 or even a OC6 for that matter. But yeah the whole paddling on one side is really lame, it hurts but its all good fun when your racing and you beat people.
#49 Tue, 08/26/2008 - 9:17pm
Shawn - Im sure if you asked a club to join, you could just come to practice whenever you can make it and just dont expect to race. Ive done that a couple of times even though I have NO desire to do 6 man. I just tell them up front and ther are always seats to fill. It is a much different workout. When I go back to my 1 man after a regatta practice I feel like a powerhouse.
#52 Tue, 08/26/2008 - 11:37pm
http://s5.video2.blip.tv/0490000168329/Mindy-Vaa1Champion505.mov
Thanks to Mindy!!!
Submitted by Shawn Michael on
