shortening iakos
if you shorten your iako, the boat will definitely be TIPPIER.
i would guess that a small change = big difference.
also with iako being curved throughout their shape, you will be changing angles while you shorten the iako. maybe consider bending new ones that are shorter. that way you still have your old ones if the boat is too tippy.
also check to see what arc your paddle takes on your recovery. make your ama too close and you'll be scratch it all the time with your paddle.
#1 Sun, 06/29/2008 - 8:58pm
True that the boat getter tippier as iakos get shorter . It`s also true that you gain better ama control by carving out Zephyr seat lower . I would do both to add performance to your canoe.
#3 Mon, 06/30/2008 - 3:03am
I had to add some foam to make me higher (on a fusion) and it feels really strong to be up some, but maybe you just need a shorter paddle and a different choke on it.
#5 Mon, 06/30/2008 - 4:07pm
I had the Fusion iakus at 36 in, usually 46 in.. Different feel, if you paddle often it is not a problem re balance.
Now I have it back at 46 because the original carbon iakus broke.
Overall, i think that other things, such as reading the ocean, are more important.
#7 Mon, 06/30/2008 - 10:46pm
47 is an extremely short paddle for someone 5'9". Have you experimented w/ other shaft lengths? Insert jc9 "shaft length" comment here...
#8 Tue, 07/01/2008 - 5:34am
OC canoes are very adjustable , thats one of the reasons I paddle them . Seat , iakos , even iako geometry is adjustable by bending them . I like a fairly low seat , low seat gives you better ama control, to get this I sculpted out the seat with 4 1/2 inch grinder with rough sandpaper disc in it. Real easy to gouge seat if youre not carefull , maybe gouge yourself too. So , go slow and finish off with 40 or so grit by hand.
#9 Tue, 07/01/2008 - 6:43am
I read somewhere before that Jr. shortened the iakos on Fuze or whatever OC boat he was using when travelling and racing and that was the only modification he did; so the threads above made me curious and I just did the same. I'm 6'1", 205 and paddle a Fuze I really got for my wife (4'11", 100 lbs). When I first got it I thought it was tippy compared to my Waveblade, but immedaitely fell in love with it. On Guam we seldom get the real downwind runs Hawaii does, but there is usually something cookin somwhere.
After cutting the iakos 2" even better! I can't see or feel any negative to how the ama rides, except it's out of the water more at the front, but does not plow at the back. A lot looser and easier to unweight the ama and take off, now I'm going to sculpt out my seat a little and see how that is.
On the never ending comments on paddle length; I was 'taught' to use a 52 or 53 for my height. When I went to Hamilton for the 1st time in 96 Walter Guild (6'4"' or 6'5"??) was using a 50 on his OC1 and I thought...I'm doing this wrong! Now I paddle a 50 in OC6 and 49/50 when va'a.
#11 Wed, 07/02/2008 - 2:06pm
Anyone shorten their iakos? Particularly on a Zephyr? Im looking to "lighten" my ama but not so much make the boat "tippier". Thoughts??
Submitted by jpi92109 on
