Some questions and comments about going FAST.....
Shawn Michael,
Send me back that busted rudder and I`ll make it like new again for free.
#1 Mon, 08/11/2008 - 2:52am
Im no expert but I have some input on #3.
I have a very thin, semi-swept, low profile rudder I designed for myself for time trials. Over a distance of 5K (flat water) I have a a faster time by almost a minute and a half. I also let a teammate use my boat and he records a 70-80 second decrease in his 5K time. Ive also let a friend borrow the rudder and he beat guys who have beat him in the past with his stock rudder. Not exactly scientific but it seems plausible that its the reduced drag.
#2 Mon, 08/11/2008 - 6:30am
As far as length goes... I measure paddle suitability by sitting on a bench and placing the paddle vertical, next to me. If I can comfortably grab the t-top without stretching my back upwards, then the length is right. This works for me in OC 6 and I would think it would be valid for OC1 considering you're measuring for your torso instead of your whole body.
#3 Mon, 08/11/2008 - 7:08am
Is that to the center or the edge of the eyebrows ??? ... some of us have big eyebrows.
#5 Mon, 08/11/2008 - 9:59pm
Shawn, how long you been paddling for?
I ask cause one thing people new to this sport (and other water sports like rowing or kayaking) do find a bigger paddle better. This has a lot to do with technique and psychology. It looks big and powerful, therefore it will make me go faster! And like most placebos, it does.
It's like the concept II rowing machines. Untrained ppl will put it on level 10, the highest resistance, as this gives them their fastest times. Trained rowers set it at resistance level 3 or 4 at most and are able to go faster with a lower stroke rate. All down to technique.
When I started paddling, I had a huge 53" paddle with a very wide blade. Most ppl thought it was a steering paddle when they first saw it. It felt great and was so powerful in the water.
That was a few years ago. Now that I've got a bit of technique under my belt, I've got a 50" (I'm 6'3" btw with a long reach) with a blade at least a 1/2 inch narrower (and shorter) and I'm finding I'm going just as fast, even moreso, using that as I was with the old tree trunk. Best of all, I'm able to keep the pace up for longer as my current paddle weighs a lot less than the old one and saves my shoulders expecially from burn-out.
As for resistance training: go for it, as long as you do it properly and not all the time. Weighing down your craft or attaching drag to it can be a great way to build strength but you need to maintain form. With hardcore resistance training it's easy to lose form.
Also best to do it early in the season (or better pre-season) along with endurance training. Then switch to speed-work as the season progresses. Having all that strength means little if you ain't got the speed to use it.
#7 Tue, 08/12/2008 - 6:57am
If NASA designed a suit to wear during races that would reduce drag from the air on your body would everyone start wearing those and start beating world records?
When it comes to speed and drag, there are certainly more variables than just the rudder. Here are some things I'd say are contributing factors to speed:
- Paddling technique - kind of an "of course" point. Proper technique that propels you forward with the least amount of wasted (negative) body motion is going to give you the biggest speed increases.
- Hull Weight - It makes sense that if you are paddling correctly the less weight you have to propel, the faster you should go and the easier it will be to keep speed going over distance.
- Body Weight - If your muscles are not able to pull your own body weight efficiently you will be slow. Add your weight and the weight of the hull and compare that to your own pulling power. Speed comes from the surplus of pulling power minus the weight. A heavier paddler will need more strength to "overcome" his own weight and have the endurance necessary to continue pulling his own weight.
- Surface Area VS Wind - The surface area of the canoe, the ama and the paddler are all "sails" to the wind. The wind will catch whatever it can. Side wind on a canoe and ama are very real points of drag. The amount of surface area you as a paddler have is also a big point of drag (what I said about a NASA suit applies to this. Although joking, what you wear is also a contributing factor to surface area and drag.)
- Rudder/Rudder Use - long rudders have more drag. Wide rudders have more drag. USING the rudder CREATES drag.
- Paddles - A long paddle can add leverage (power applicaton), but can also cause a late exit from the water. A late exit can cause drag (and you might be pulling the boat down by applying power toward the end of the stroke/exit and increasing the wetted surface, thereby increasing drag). A longer paddle can also compromise the shoulder usage and tire out your smaller muscles, thereby making it harder to keep your speed up. Also too short of a paddle can compromise your body position and cause you to lean too much causing a lot of weight being thrown around (see above about wasted body movements).
There are a lot of factors that go into getting speed, minimizing drag and improving efficiency. Paddling better is probably the cheapest though!
#8 Tue, 08/12/2008 - 8:12am
Shawn Michael,....g'day mate
Paddle length......I've got a really crook shoulder from playing Rugby. My first coach was a Kiwi and he determined my paddle length by the "stand up straight & the paddle should fit comfortably just under the armpit" method.....came out at about 53"........shoulder hurt nearly every session
http://www.xylobladz.com/
Here's how most here do it....from Xylobladz website.....click on the Tools & Tables on the left (it might be on the right in your hemisphere....hehehe)........most of us these days then reduce the answer by 1-2" for OC1 in particular and to ease the strain on the shoulders.....thats in the fine print at the bottom of the table......
I agree that for a bigger guy (I'm 6ft, @220lbs) it feels logical to go bigger paddle.....at the start.....but paddling is brains first, brawn second......as technique improves.....go smaller and shorter to go longer and smoother and faster, and more economical....
#11 Tue, 08/12/2008 - 12:15pm
Body weight does help in the wind because the wind cannot push a heavier paddler as easily as it can a lighter one, but still larger surface area doesn't help any.
I guess what I meant about the longer paddle was that it is easier to bring back the blade really far. The main reason I believe for this is that the leverage from the longer paddle tends to make one believe that you can still pull strong at the end of the stroke (because it feels like you still have a solid pull). The problem is that the solid pull at the end of the stroke brings the boat down and kills your glide.
Long up front. Short in the back. Initiate the exit when your shoulders square up with the boat.
#12 Tue, 08/12/2008 - 12:17pm
I should add....
I think the matrix puts me at around the 51" mark...
I now paddle with a 50" Kialoa Lanikai.....I know its bigger, but its light........AND BEAUTIFUL......
I cut my other paddle, a local all-carbon "Carbon Culture" blade down to 49"........I also steer OC6 (I know, you're all laughing at the fat guy steering) with a 49".....
You sound like you work on your shoulders, so go with what is comfortable and gets results.....when you adjust paddle length, other adjustments to style and body position may be made......you might find them uncomfortable at first, but I like experimenting to find the right compromise to help me extend my wretched body's sporting life!
I know the angst associated with the notion of destroying my paddle to the new-found comfort and peace-of-mind of paddling with a radically shortened paddle.....I've done it for at least half of our little club and they have all felt it to be beneficial.....gotta go....got two more paddles to cut down!
#13 Tue, 08/12/2008 - 12:41pm
I think most paddlers would agree that shorter paddles are now more popular. One if the best investments you can make is a GPS that gives real time speed...I think that what 'feels' strong and powerful is not always 'fast', whether OC1 or OC6. Technique is way more important than fitness/strength...especially at first. I'm sure many can talk story about working their hardest and being passed by another crew or another OC1 where the other guy(s) didn't seem to be working very hard at all...and the when you upped your effort to stay with them, the worse it got! I call it having to 'muscle' the boat rather than working for the glide.
One of the key elements in a smooth, efficient stroke is to have the paddle out at the knee, or just a hair behind it. The Tahitians teach that your elbow should finish at your side, not flared or angeled out. When your elbow is at your torso, your shoulders are square to the canoe, the blade is still vertical (not angeled back or starting to pull the kanu down) and it should be starting to come out of the water, The release is smooth and relaxed; you can actually hear the gurgle if you pull too far back or catch the ater on your exit.
#14 Tue, 08/12/2008 - 1:19pm
Hey Olgguys...
again, im no expert, but Ive asked our steersman to ban all electronics from our boat because its a hell of a distraction. I think the gps is great in the 1 man but I feel like the GPS hinders us from swinging together cuz we ficus to much on hull speed instead of technique and timing. We have one guy who is like a freakin cicuit city......gps, heart rate, watch with timer. How the hell can you focus on the swing when youre lookin at all that sheeeawt?
#15 Tue, 08/12/2008 - 1:43pm
Gee I never thought info or feedback would hinder paddling better, but I guess you could just have the steersman look at the speed and let you all know when it was clicking; you could vary stroke rate, or power or even seats and or paddles to see what really works, as opposed to what just feels faster.
(I'm envisioning all 6 trying to look at their wrist mounted Garmns in rythm, I think that WOULD foul you up...)
I wonder has anyone ever used one of those Tempo Trainers that swimmers put under their caps or goggle flaps that sound a beep at the cadence you desire to teach strokers tempo?
#16 Tue, 08/12/2008 - 2:24pm
Shaun, have you read this article by my good paddling friend Leo Young, a human movement Professor.
http://rambos-locker.blogspot.com/2006/07/long-or-short-you-decide.html
He's a tall guy and top OC paddler. He also holds the world record for indoor Erg Concept 2 Paddling and has a very successful gym equipment manufacturing business. http://www.calgym.com.au
Definitely someone worth taking advice from. I do.
Leo's Resume
Leo Young - Managing Director
(B. App. Sci. [Sport Sci.], B.Bus., Grad. Dip. Clin. Nutr., C.S.C.S)
Leo has 30 years experience in the fitness industry, including fitness centre establishment and management, staff training and consultancy, as well as gymnasium equipment design. Leo has also successfully coached some of Australia's finest Olympic and world class athletes in a wide variety of sports. He has personally competed at international / national level in several sports and currently holds multiple open world records in indoor rowing, canoeing and kayaking. Leo was formally the "Director of Education and Consultancy Services" for Fitlink Australia and is in high demand as a lecturer at fitness industry conventions. He is also the co-author of the textbook "Fitness -a systematic approach", widely used in Fitness Leader training courses nationally.
#18 Tue, 08/12/2008 - 11:44pm
I have to admit for once I completely agree with aqua! Im new but I feel like less is better. Its a;; about the feel. What good is all the tech stuff if you dont feel good. Im a believer in proper technique with personal tweeking to make it feel good and right but I only paddle one man. I know in 6 man its all about blending and timing so that seems to be a whole different ball game.
#19 Tue, 08/12/2008 - 11:50pm
Shawn - Again, im new also but do you paddle with anyone? Or mostly solo? I paddled for several months solo when I was brand spankin new. I made gains mainly because I was so new. But when I started paddling with a group and started chasing guys on a regular basis I really started making gains. Ive caught a few of them! The faster the guys are that im chasing, the faster I seem to go.
#20 Tue, 08/12/2008 - 11:55pm
Rambo, your post got me thinking, as I increased my paddle lenghth to 53" this year and have had ups & downs in the process.
I think its important to take knowledge from all aspects of paddling, sports and martial arts etc. What Leo is stating is hard to argue, he's right. However, theres another side to what he's stating; the more preasure applied to the paddle does not directly equal less power to the haul, (correct me if im wrong). That statement also works in reverse, more pressure doest not always equal haul speed.
Some paddlers do have the power or leverage to maintain in a lower gear while increasing glide. Similar to the larger blade concept. I guess it comes down to a balance of efficiency and available power/energy.
Thoughts?
#21 Wed, 08/13/2008 - 12:13am
Still on topic but just a side step.
I have been trialling a Kialoa Lono (Whacky shaft) and a Keone (straight carbon shaft) both 50 inch, for a few months and i found i needed a longer paddle with the whacky, The reason for this in my opinion, is because of the difference in the effective blade angle presented to the water at the catch.
If you hold both paddles out in front of you in opposite hands in your normal bottom hand position on the shaft, and place your forearms at the same angle, the whacky blade is 3 inches further forward than the straight shaft and higher off the floor.
Effectively the whacky gives you a longer reach, however to take full advantage i believe the blade (not the shaft) should be longer (probably the reason Tahitian paddles have longer blades) to overcome the distance from the floor. Funnily enough, a longer shaft also has a similar effect even though your bottom hand on the shaft is in the same place. I'm not able to explain the reason for that, but 2 inches longer feels much more effective.
So what i'm getting at here, is if you are going to purchase or trial a Whacky, get it a couple inches longer than you would a straight shaft as you can always cut it down later and reattach the "T" top.
#23 Wed, 08/13/2008 - 1:27am
rambo,
i don't have a wacky blade but i compared a straight shaft blade side by side, and the ttops and blades were at the same position- with the difference being in the shaft. (this is different than the comparison you did, where you compared the blades while holding it the same way)
i thought the whole point of the wacky shaft was to get the bottom wrist at a more neutral anatomical postion at the same blade position...
if you bend your wrist the same way as a straight shaft then it makes sense that the wacky would be further out... but the question is: do you want that?
then again, maybe that could be an alternate but equally beneficial use for the design.
#24 Wed, 08/13/2008 - 5:33am
Well, 'feel' is great, we all want to feel right in the boat; and I'd guess that as a rule when it 'feels' right you are probably more efficient and so on...I know when the V6 gets gliding on a plane, it seems to get easy and that is magic.
But Shauns question was about going 'fast', and in my experience and confirming with other V1 guys here, that working hard and pulling your mightiest may not always equal going fast. The GPS can give you actual results, not just what 'feels' good, I've been surprised at the difference I can see in varying techniques, angles, etc..
A few year ago we used impellor speedometers with a little blade glued under the hull, they did give you accurate, real time speeds but kept getting knocked off. I use a Garmin 305 and it seems close enough for me, I guess there is a couple of seconds delay but I can live with that, The little maps you look at on the computer after are cool too.
I've been lucky enough to do some coaching and there is a wealth of info from other aquatic/triathlon disciplines that we can adapt to OC. Rambo's locker is the gateway to much of that info.
#25 Wed, 08/13/2008 - 12:08pm
Datcho said .... i thought the whole point of the wacky shaft was to get the bottom wrist at a more neutral anatomical postion at the same blade position…
It is the main reason for the Whacky, the hand position, but the blade still enters the water flatter and further back than a normal single bend (of the same length), so a longer blade (ala Tahitian) keeps the entry point in the same place.
I'll post a photo and show what i mean.
All i'm trying to point out, is when you order a Whacky, go with a longer length that way it can be easily cut down to suit.
#26 Wed, 08/13/2008 - 12:33pm
What happens to the angle of the keone if you grab it with your top hand and put it in the angle that you would start your stroke, My guess is is pulls back in line and the blade angles line up, as well as the tee tops.
The idea of the wacky is to neutralize the wrist which it has obviously done in the photo, But based on where you have the Keone grip the wrist will also have the neutral position, I would doubt that if you take the same photo, but add the left hand to he top grip you will get different results
Also leaning back in the photo will create different results, Position yourself sitting down and simulate proper stroke position,
#28 Wed, 08/13/2008 - 6:19pm
Yes Chris, in a static environment tilting the Keone back to line up with the Whacky top and bottom is possible, but then the bottom hand position of the Whacky moves FORWARD considerably and this is the reason I'm suggesting you need a longer blade, WHICH IS THE POINT I'M TRYING TO MAKE, It ends up higher off the water.
Also it appears in practice, because you have the extra range of flexibility with the bottom hand using the whacky, you tend to take advantage of the fact and reach further, and this is where the blade starts to become flatter to the water.
It maybe that by having the extra 2'' in length and using the correct technique for this paddle, that you can then extract the most from it.
This has been my experience with it anyway and the extra 2'' now feels more beneficial.
Has anyone else paddling a whacky found their stroke at the catch is shorter using the same size as their single bend paddle??
With the blades flat and in the same plane the tops are still different and the bottom hand positions are way different.
BTW. both these paddles were made with 10 degree blade angles.
#29 Wed, 08/13/2008 - 8:03pm
Rambo,
I have a 50" Lono "whacky shaft" that I bought as my one of my first paddles to use with my OC-1. Now, I found out I feel better using 49" size paddles, but the Lono still feels fine when I do use it.
As for the catch compared to my 50" straight shaft Gillespie(when I was using it), I haven't really noticed it being shorter.
Looking at my Lono from the side, the point where the shaft goes into the blade looks like the angle is wrong for it to be going in. In fact, if you look at the picture you posted, it looks like it should be straighter going in but it looks like it is forward which is causing the top end to stick further away from the wall than the Keone. I did the same thing with my paddles and got the same thing you posted with the Lono's top further away.
#30 Thu, 08/14/2008 - 3:06am
Here I am talking about southern Californias often relatively flat conditions.
I am not tall (6ft) but I have a LONG torso...I hit my head in most cars that fit tall people. I started with a 51 and maxed out my 2.5 mile time 30 minutes. Then I went to a 52, that day I got loop in 28min, when I switched to the 53 I got 27min...still slow I know but the long paddle feels good though I have been assured I will damage my shoulders, no problem but it seems that a long paddle give such good reach, solid catch and a longer pull...I am talking over a 12 mile course of flat water so it is not a fluke. I want to try a 54. How do you know when the paddle is too long? Other than sore shoulders? I see some long paddles in the big race photos, Kai Bartlett being one. When I get my new canoe (which might sit lower) I will figure out how to link a vid so that I can get feedback on the length of the paddle and hopefully some comments on my stroke. Longer paddle = faster, is it just me?
As I have been looking into the tiger Pahoa for a new boat that will seat my big ass I notice that Tiger custom builds his boats so that the paddlers weight in centered in the boat. How important to having a good "flat water trim" is it to be centered in the canoe?
It is amazing that a few long blades of grass stuck in the rudder can be felt clearly as drag. SO it would seem that having a big surf rudder dragging through flat water would really add up. I bought a flat water rudder that was about half the length of the surf rudder and it seemed to steer the canoe just fine...I hit a rock and broke it before I could time my speed but it would seem that the rudder is a pretty big deal in racing, it would seem like a big advantage to have a smaller/thinner rudder...is this true or does your boat track more poorly with a small rudder? Goto wrote: "If you are pulling your boat even a little bit diagonally, you’ll end up side-loading your rudder and the draft of your boat = more drag/less speed." So it would seem you want the rudder with the least slimmest profile that will keep the boat tracking straight and give you steering responsiveness you need for the type of water you are in.
Just thought of this watching the olympics...the canadian 8 (rowing) had such a fast and powerful start, they made the others teams in the heat look like they were tied to the dock! The commentator said that they improved their strength so much by having 4 of the team pull the other 4 in some drills they do in training. I know cyclists do hill work with only one foot clipped in...I guess this one has been around already but I guess it is unweighted sprints or adding resistance. I know that when I come off a leg of really strong headwind everything else feels easy.
Thanks for any comments on the above
Shawn
Submitted by Shawn Michael on
