GoPro Fogging
GoPro Fogging
If you're having fogging problems, this permanent solution may be what you need.
http://rambos-locker.blogspot.com/2009/01/permanently-preventing-foggin…
Ramboscie
Submitted by Rambo on
Might be a good breather for your Canoe and Ama too.
#1 Thu, 01/01/2009 - 9:00pm
Will it fog in warm conditions, or only in cold water/air conditions?
#2 Fri, 01/02/2009 - 6:37am
Seems to fog more in humidy and hot days after constant splashing from ocean. I think on days like this, the temp inside the case is elevated and when it gets splashed condensation forms on the inside of the lens. As soon as you open the case the fogging goes away in a few mins. Same if i put a hole in the case.
#3 Fri, 01/02/2009 - 6:45am
Doesn't fog in Victoria!!!! Not on the camera anyway.
#4 Sat, 01/03/2009 - 12:03am
Page loaded in 0.161 seconds.
