proper amounts of electrolytes
Here is a summary table of mixed drinks:
http://oc1design.blogspot.com/search/label/OC%201%20Nutrition
Salt loss in sweat up to 1 gram per hour is correct.
Just add more of it to your drink, don't need a pil for this . You will likely not mind because you are craving.
The Tahitian method sounds great.
A good idea would be to check your weight before and after a practice without drinking.
That gives you an idea about how much fluid you need.
As long as you can pee your salt content should be ok.
If a skin fold stands up and does not flatten after pinching the back of your hand you need salt and water.
Salt and water = always together, do not separate
#1 Sun, 01/04/2009 - 12:45am
Haven't checked that gatorade out, but I've always steered away from their products because of the sugar content.
I use cytomax. Brings me back from the dead every time without the sugar rush...LNB
#3 Sun, 01/04/2009 - 3:51am
I`ve been drinking Cytomax since my bike racing days , it worked really good then to keep me from bonking in a long race or ride and it works good now in long distance canoe racing .
Try it you`ll like it .....
#4 Sun, 01/04/2009 - 5:59am
personally i find the Hammer Gel Products to work for endurance races over 2hrs. Endurolytes for electrolytes pre-race and Sustained Energy during the race. the products due not use artificial flavors, colors, or sweeteners. you can check out their websites for data.
#5 Sun, 01/04/2009 - 7:33am
Every body is different and has different needs.
I don't seem to need as much water as some others. Cytomax has always been perfect for me and what I need for long workouts. I followup with a few figs and I'm good for several hours.
Definately end with a 3 or 4:1 carb:protein recovery after a 2 plus hour workout. 16 oz of low fat choc milk is a winner. It's amazing how fast you can recover to go again if needed.
Canned wild salmon or sardines and kashi crackers is a good recovery too. Been hitting that lately.
Don't forget those amazing bananas. An outstanding food for any occassion or reason...LNB
#6 Sun, 01/04/2009 - 7:59am
As someone noted, every body is different, but I also have had good luck with the HEED products by Hammer. For races, I mix up shots of hammer gel in a small squeezy flask to take during rests - that way I can enjoy some plain water, some HEED (electrolyte water), and still get a lot of calories.
Hammer also makes a super endurance product that I haven't yet tried called Peretuem, details here:
http://www.hammernutrition.com/za/HNT?PAGE=PRODUCT&CAT=SUPFUELS.HAM.NUT…
Anyone given that a try for a long race day?
#8 Sun, 01/04/2009 - 9:48am
Generally, the sweeter something is, the faster it will go into your blood and the faster and higher your Insulin will peak - not necessarily good.
Less sweet - think oatmeal - sugars are taken up more slowly and charge your system more moderately, better for long endurance.
Perpetuem has numbers that are close to what I think should be replaced.
Magnesium is only needed if you do high volume training over a longer time period.
#9 Sun, 01/04/2009 - 10:30am
My wife who is a marathon runner and triathlete got me onto e-load. The taste is palatable and I have noticed the difference.
http://www.medioncorp.com/hm/eload/inside.php?sid=16
Jeff
#12 Mon, 01/05/2009 - 2:11am
Ive read that for a good hard race you need about .5 - 1 gram per hour of sodium. In addition you also need potassium but not sure how much. I always thought that good old cytomax was enough to cover but according to the label its not anywhere near enough. Does anyone know of a drink that covers this? Or is it just assumed that in a race 2 hours or longer that you will stop long enough to pop a sodium pill? I paddle in Hawaii and sweat alot so I know I need to replace sodium. So far I have just used the Tahitian method of dragging my hand for a second and licking it for the salt - hi-tech I know but it seems like the simplest methods work best.
Submitted by jpi92109 on
