Underwater camera housing
Ecky, your eyes must have lit up when you saw that plug at the hardware store, saved you a lot of work.
I've modified the Torch housing now so that it will mount on a mono pod or my Fig Fig Wheel. All the connections to the cam go thru a seal-able port so now the cam is fully protected from salt air. Need to add a simple mechanical button to press the power on/off button and it's complete. Just a bit of added assurance against possibly scoring a "cowboy " Jet Ski Driver who takes a sharp turn while I've got two hands on the Cam wheel and i take a swim....hahaha
#1 Fri, 01/02/2009 - 9:24pm
Leave the LCD closed then turn on the power, the green lite stays on. Insert into housing and use the remote.
Or disable the LCD micro switch.
Cut a hole in the acrylic and glue glass over the hole.
Better still, buy a 52mm adapter ring, glue it on, then screw on a 52mm clear uv filter.
#3 Fri, 01/02/2009 - 11:19pm
eckhart,
Great housing.
Do you have a picture of the housing with the camera in it?
#5 Sat, 01/03/2009 - 9:36am
Ecky, did you leave room for a wide angle lens?? If not you can use one of these clip on type, they only add 1/2 " to the length of the cam.
http://www.amazon.com/Raynox-303-QC-Converter/dp/B00009UTK3/ref=pd_bxgy…
#7 Sat, 01/03/2009 - 4:28pm
Have you thought about heating the acrylic tube in a tub of water placed in an oven to soften it up? Then forming it into a rectangle to better form it to the camera. Of course you'd have to redesign the end plug.
#8 Sat, 01/03/2009 - 4:57pm
In case you are interested in the camcorder underwater housing please have a look. This is the first model and will likely undergo some minor changes, such as getting a handle, adding a camera hood, some rubber for shock damping just in case. I used acrylic to be able to use the infrared remote control. Many people use PVC, I don't think it is any cheaper overall. Total cost: $ 30.
The design is quite simple. Acrylic can be cut with a saw, or better scored, and then be sanded to the final shape. The only thing that you need to make is the disk-shaped end plate - no problem with a little patience.
Buy the parts on Oahu:
ACE hardware for the plug $ 7.85
Min-Plastic ( King/Dillingham ) Acrylic tube - $ 34/ foot
Min-Plastic Special glue and applicator - $ ~ 8
Picture and description:
http://www.oc1design.blogspot.com
