I need a canoe storage device that will hang my canoe from the ceiling>>>any help?
Submitted by iaukea on Sat, 11/14/2009 - 10:36pm
Page loaded in 0.216 seconds.
Read some previous suggestions here.
http://www.ocpaddler.com/node/2636
#1 Sun, 11/15/2009 - 3:02am
The easiest and cheapest:
Two tiedown straps. Screw the tiedowns to crossbeams at a length that your boat will fit, connect each tiedown so they hang down with a loop and just slide your canoe between them and pull the tiedowns tight to the height you want your canoe to hang. Easy!!
#2 Sun, 11/15/2009 - 12:36pm
Even cheaper! Hang rope loops from roof joists and use garden hose pieces for the bottom.
#3 Sun, 11/15/2009 - 5:38pm
xxx
#4 Sat, 04/02/2011 - 10:02am
There are various options and structures for storing the kayak or canoe in the garage, but effective and inexpensive solution "do it yourself" at:
http://www.craigmarine.info/yacht_boat/builders/canoe_boat/Canoe-Storage.htm
you can get familiar with different storage tools and brands that might help.
#5 Mon, 05/05/2014 - 3:16am
