I have a Fusion who's ama was recently torn off the iako after catching waves not sure if it can be repaired but im wondering if I can use another ama from another kanu, any ideas will be greatly appreciated
Submitted by 2strokes on Sat, 11/13/2010 - 9:37am
All Outrigger Connection OC1 amas and iakos are interchangeable. so any ama from any OC1 from Outrigger Connection should work Ok.
You should try the new Osprey ama ...
Sun, 11/14/2010 - 7:19pm
HK- the front iako lock buttons are different for the Osprey ama from the Fusion ama.
Wed, 11/17/2010 - 9:44am
got a drill?
Wed, 11/17/2010 - 3:37pm
Tap it?
Fri, 11/19/2010 - 7:23pm
Drill the iako not the canoe. pop clip into new hole- make sure you get the alignment right before you drill, or ask Karel to do it for you.
Sun, 11/21/2010 - 6:35am
