new iato design
Hi there.
Just for the art of mindgame :
Anyone ever thought of a design involving one iato instead of two ?
Could be interesting in order to clear the front, and play with ama balance fore and aft the main hull.
Don't know any structural resistance involved here, don't blame me I'm not a designer nor a builder !
Submitted by fabrice on Fri, 11/26/2010 - 1:37am
with respect. The Huki has a wing for surf ski that could do a simalar thing.
#1 Fri, 11/26/2010 - 11:11am
mulus is correct ... Jude calls them a Gull Wing. And Huki has made what they call a one-person dragonboat, that looks like a surfski with the Gull Wing built in and paddled with single blade. You can see it at www.huki.com
But, the Gull Wing might be more like sponsons on both sides of the rather than an ama with one iako.
#2 Fri, 11/26/2010 - 7:11pm
thanks mulus and osprey for the info.
A one side "huki gull wing", maybe a bit farther from hull centerline, a bit longer to provide enough buoyancy, but definitely sharing the concept, position and aesthetics was what I had in mind.
#3 Sat, 11/27/2010 - 12:26am
Now where I going put my hammock so I can go sleep?
#4 Sat, 11/27/2010 - 10:03am
I've seen a canoe where both iako are mounted behind the paddler about 6" apart. It didn't work too good because the forces hitting the front of the ama would cause the whole rig to torque and twist. Seems like there wasn't enough separation between the iako. So if you tried to do something like have a single iako I'd think the thing would have to be pretty damn beefy. Maybe a hollow moulded beam of some sort? Then maybe you'd run into weight issues...
#5 Sat, 11/27/2010 - 11:41am
Yep on that ... Just 'cause you can doesn't mean you should ...
I feel same about some of the current popular music.
#6 Sat, 11/27/2010 - 2:10pm
Or surfski with a outrigger paddle race. on flat water of course
#7 Sun, 11/28/2010 - 6:21am
when i was in 18's we actually had a time trial in surfski's with canoe paddles, it was pretty nuts
#8 Sun, 11/28/2010 - 10:48am
i paddle da tin roof wit a shovel!!!
#9 Sun, 11/28/2010 - 5:10pm
Found in "Paddler's guide to putrigger canoeing" by Steve West. page 134.
You can buy it here : http://www.kanuculture.com/
#10 Sun, 11/28/2010 - 7:55pm
Salut Hiro !
Thanks !
Interesting to read "latter banned because both iako were behind the paddler" ...
Class rule issue then, not technical flaw ...
#11 Sun, 11/28/2010 - 8:52pm
Page loaded in 0.114 seconds.
