any suggestions on removing stickers from a one man. what to use and what not as far as getting rid of the stickiness without damaging the boat or paint. thanks
Submitted by unklekahi on Fri, 06/11/2010 - 7:56pm
Page loaded in 0.097 seconds.
A Paint Thinner dampened rag and a bit of patience. Not Lacquer Thinner or Acetone.
Fri, 06/11/2010 - 8:28pm
goof off will do the trick
Fri, 06/11/2010 - 9:03pm
With dome stickers, an oily cloth works well. Clean with soap after.
Fri, 06/11/2010 - 9:10pm
Use a blow dryer on low heat. The sticker should peel right off. If there is residual gunk, use Goo Gone.
Fri, 06/11/2010 - 9:38pm
Goo Gone.... the bestest
Fri, 06/11/2010 - 10:14pm
No need try the rest...GOO GONE the best!
Sat, 06/12/2010 - 3:46pm
I usually scrape them off with a razor blade and goof off or goo gone the rest. use a heat gun if it is really stuck on there but keep it moving and a good distance off the canoe. you can mess up a lot of epoxies by localizing heat for too long.
Sun, 06/13/2010 - 9:16pm
Benzine from a graphic arts supplier will do the job, however somewhat toxicly.
Mon, 06/14/2010 - 5:36am
I fix it with my eyes.. stare at 'em for a real long time and they magically dissapear. This technique also works for dings and chicks, stare at 'em awkwardly for a bit and boom..gone. All nontoxic except the latter might get ya hurt
Mon, 06/14/2010 - 6:46am
