Best method for attaching V1 Fai-3 Iatoes to ama and boat?
i have heard old inner tubes, but what is the best wrapping technique and is there a better option? Thanks in advance.
Submitted by aaiello on Sun, 10/30/2011 - 5:13am
Better than bike inner tube tire is car inner tube. Thicker rubber. Then cut into thin strips.
Put a strip of rubber between wood block on vaa and iato. Also between wood bock on ama and iato so that it gets better grip and doesn't slid. Also protects the wood.
Then just pull tight and wrap around and around. Depending on length of strips you can cross in and out of risers or can use one strip for inside and for outside.
#1 Sun, 10/30/2011 - 9:28pm
Hiro C. posted about rigging a V1 on his blogsite.
http://tuaruavaa.blogspot.com/2008/11/monter-et-rgler-son-v1.html
Google translate link
http://translate.google.com/translate?u=http%3A%2F%2Ftuaruavaa.blogspot....
#2 Sun, 10/30/2011 - 10:01pm
Yep ! Same principles for V1 V3 or V6.
I like to use bike tube for V1.
For V3 and V6 better use thicker rubber, especialy in the ocean.
I'im lucky, I have a souce of excavator/bulldozer's inner tubes.
I think it's better to use two strips of rubber on each riser : one on the left side of the hull, another on the right side. That way, if you have to insert wood blocks later, you won't have to unrig everything.
#3 Sun, 10/30/2011 - 11:37pm
Thanks Hiro, E7M and Tim. That Blog was the ticket. Mahalo
#4 Tue, 11/01/2011 - 3:08pm
Page loaded in 0.125 seconds.
