Hody cable repair (inside hull)
Our dragon boat club has two Hody OC1s for training on the flat water, Schuylkill River. One of the cables "popped" and is inside the hull. I need advice on how to get the cable from inside the hull out through the little tiny hole in order to rerig the peddles/steering. The Hody has a 4 inch circle deck plate that covers the access to the rudder mechanics.
Thanks for any advice.
Submitted by erastrick on Sat, 09/08/2012 - 5:13am
I assume there is a cable guide which might be broken or has come out of the fromt end. If this is the case, replace the cable guide (probably 1/8" or whatever easily accepts 1/16" SS 1X19 cable.). You'll probably add an inspection place up front. Good luck.
#1 Sun, 09/09/2012 - 8:24am
Page loaded in 0.110 seconds.
