Seat Velcro
Aloha, I am rehabbing a Kamanu Composites Kainalu and the seat Velcro is toast.
can someone recommend an appropriate glue for sticking down the replacement Velcro strips?
mahalo in advance,
Submitted by Openocean on Wed, 11/01/2017 - 11:55am
I have found that contact cement does not hold up....tried Goop (very sticky silicone based glue) and never had a problem on either the seat surface or a cleaned and prepped deck surface.
#1 Thu, 11/09/2017 - 3:41pm
5 min epoxy. just make sure you scuff up both sides with sand paper so it bonds well.
use masking tape to keep the glue in a nice area.
#2 Fri, 11/10/2017 - 4:04am
3M Scotch-Weld 3532 (slow cure brown) or 3535 (fast cure white) 2 part Urethane adhesive. So far, no damage yet to composite deck, cockpit or hull.
#3 Sat, 11/18/2017 - 11:29pm
Page loaded in 0.101 seconds.
